My drivers side headlight is flicker when it's been on for a while..passengers side is fine...bad connection?
Call Andrew at coolbulbs. I have ordered/replaced all four ballasts. Waiting on fog ballasts to arrive. I have read somewhere a flicker can be the bulb itself, which is rare. The ballast issue will have the light turn off completely and the only short term remedy is to turn the light switch off and on again for a second.
The ballasts run 30.00 each and the bulbs are much cheaper.
Buzz
He said i probably need a relay...so i am going to get that first and see if it fixes it
Might need a relay.mine only flickers when care is on..when it's off..it stops
Might need a relay.
No idea if its a simple plug and play or if you have to get down and dirty.
Mine started to do that a few weeks after installing. I unplugged and re-plugged everything in and it seemed to resolve that issue. Been good for 3 months now.
so i unplugged everything and plugged it back in..still flickers when car is on...when car is off and just lights on..no flicker...has something to do with the power then...so i think the relay will fix it
I had tons of issue with coolbulbs. Andrew was helpful and nice but I just got tired of replacing and switching parts.
Threw some Phillips HIR bulbs in for now. They are no better than crap oem bulbs in my opinion. Leaning towards a diode dynamics kit.
Having lights turn out when driving, especially with my kids in the back seat, pretty damn scary.
Relay didn't fix the issue unfortunately
I have the exact same ride as you with Coolbulbs...strange
Buzz
'Oh, you are a Patriots fan...explains alot!
