ryanb99
- February 18, 2014
- 2007 Ford Explorer
Hi Forum. I am new here. I am fighting a problem with my wife's ford explorer and i decided to find a forum since i solve a lot of problems with my Honda on a forum.
My 2007 Ford Explorer V6 will not reach operating temp when turning engine on no matter how long it sits there and you can get no heat. As soon as you start driving down the road the temp gauge will start moving up above normal operating temp and then settle back down to normal and you get heat. It happens within a matter of seconds. Temp gauge flies up and back down.
I initially thought this was air in the system after doing a drain/refill because that is when the problem started. I have eliminated that i think. It had a coolant leak at the thermostat housing so i just finished replacing the thermostat housing, thermostat, and sensor. Didn't solve my problem. I haven't tried bleeding the system since i just finished, but i am going to do that now.
I don't know a whole lot about cars. I am just starting to try and learn all these things and do my own work. Any insight is greatly appreciated.
Ryan B.
Ryan B.
