pete kauenhofen
- February 4, 2018
- Aylmer, Ontario
- 1998 Explorer EB 5.0l
ok, its been said before, I perused through many, many threads, which almost ALL seem to start with a headers related question, then go severely off topic!, if I am understanding correctly, Torque monster headers are No longer in production, and were also very highly priced... so, IS there another option? the reading I've done is pointing towards a "NO", surely someone has found something by now no??
- I'm engaged in 3 projects, a '66 EB that's getting a '98 Expo mill, which is staying efi and getting a flywheel for a manual trans, and reading on here has me thinking I may need a new Hm balancer? or no if I keep the accessories as is...
- second is a '73 EB also getting an Expo mill, but likely getting carb and all that, so fairly easy
- 3rd is a drag race project, using a '98 Expo, stripped down and re-skinned as a Ranger, and we all know how much the Rangers lack traction, so, keep the expo 4x4 and run it that way!
so about headers? has anyone tried the "P" head specific ones available from BC Bronco's, or Bronco Hut? I bought a set of the Bronco Hut units, look like a very good quality build, ceramic coated, made specifically for the P head 302, and designed to fit into the tight engine bay of an early Bronco, which, upon a visual inspection, look VERY promising to fit the Expo...also looking for quick tips on bolt on mods for this mill, like injectors, mass air, TB etc...does anyone have knowledge on what works well? here in Ontario, there seems to be a void now as these are getting too old to be played with it seems, and all have moved on and upward! I'm guessing/hoping that with a much better exhaust and the induction system upgraded, a program change is in order. looks like I'll be getting the SCT x4 with a tune, to change shifts, delete PATS and anything else stupid, and write a good curve for waking this motor up! kinda wonder how much abuse that trans and Tcase are going to take...anyone have an idea here? lastly, if I was to change cams, who has a known favourite? and did you have to change the V springs and rockers? do the heads need machining to accept new springs for the exhaust valves? thinking about changing to a 1.7 ratio rocker, but reading about clearance issues with the compressed spring...
