Courier 5r55w Trans swap question
Courier Bill
Curra Queensland
2005 4x4 courier 4 door
Hi folks i>m an Aussie but please dont hold that against me or i will send you a truck load of drop bears, Seewhat you can do with those, Seriously i need some advise, I have just purchased a 2005 V6 4Ltr. Courier with a blown tranny & cant locate a replacement, However i have had a great offer on the same model but in 2x4, My question is can i simply change the extension housing to fit it or is there more to it, It looks to me to be possable !! ??
...Bill...
RangerX
Elite Ranger
Staff member
Moderator
Omao, Kauai
'93 Ranger XLT 4X4
Welcome Bill!
There's a few Aussies here already, so I guess we'll have to let you in, too!
I'd like to move your post into a section where you could get proper answers, but I'm not sure, is Courier what Explorers are called down under?
Courier Bill
Curra Queensland
More like the ranger series, Made in South Africa I believe, The same 4ltr. V6 & same faulty 5r55W 5 speed auto with the same Servo pin oval bore problems !!
RangerX
Elite Ranger
Staff member
Moderator
Omao, Kauai
'93 Ranger XLT 4X4
Ah okay. Moving this to the trans section, since that's the root of your problem.
D 3-4 5r55w flare Transmissions & Transfer Cases 3
A 5r55w No forward at engine hot Transmissions & Transfer Cases 1
M 5r55w solenoid pack compatibility Transmissions & Transfer Cases 1
P Solved 5R55W/S O/Drive flashing fault on a 2009 Ranger in Australia. Transmissions & Transfer Cases 35
D 5r55w diy options Transmissions & Transfer Cases 5
J Hi All my first time dose rebuild kit for 5r55w fit 5r55s Transmissions & Transfer Cases 1
P need to replace or rebuild my 5r55w... what to do? Transmissions & Transfer Cases 3
S 5r55w blown out OD servo cover Please help Transmissions & Transfer Cases 14
C 2002 explorer p0741 code. 5r55w transmission problems. OD light flashing. Transmissions & Transfer Cases 2
T 5r55w no forward or reverse gears. Transmissions & Transfer Cases 2
T 2002 Explorer with a broken servo piston in a 5R55W transmission. Transmissions & Transfer Cases 4
A 05 explorer 5r55w 2-3 shift delay Transmissions & Transfer Cases 1
K 5R55w to 5R55S swap Transmissions & Transfer Cases 6
J Has someone swapped a 5r55w to a 5r55s? Transmissions & Transfer Cases 7
L 5R55W Transmission Showing P0775, P0732, P0735 Transmissions & Transfer Cases 24
R New member 5R55S replace the 5R55W? Transmissions & Transfer Cases 5
C 5R55w Servo fix Transmissions & Transfer Cases 12
C 5R55W 6 cyl and 8 cyl the same? Transmissions & Transfer Cases 3
M 5R55W No 3rd Gear, out of ideas Transmissions & Transfer Cases 1
0 5r55w 4.6 2wd help Transmissions & Transfer Cases 8
L 5R55W transmission on 03 explorer leaking Transmissions & Transfer Cases 3
G Swapped 5R55S for 5R55W, should I swap pcm as well? Transmissions & Transfer Cases 7
J 02 eb explorer 4.6l 4x2 trans error 5r55w Transmissions & Transfer Cases 0
R 5r55w won't shift unless in limp mode Transmissions & Transfer Cases 4
R rebuilding trans help 5r55w Transmissions & Transfer Cases 6
H 5r55W/S/N Solenoid pack repair instead of replace Transmissions & Transfer Cases 7
F 5r55w manual transfer case swap Transmissions & Transfer Cases 4
P 5r55w and 5r55s transmissions Transmissions & Transfer Cases 4
B Where to buy a 5R55w Solenoid Pack?? Transmissions & Transfer Cases 2
S Noise at shift change 5r55w Transmissions & Transfer Cases 6
S 5r55w SELECTIVE THRUST WASHER (FRONT CLEARANCE) Transmissions & Transfer Cases 2
L 5r55w tranny not going into low or reverse Transmissions & Transfer Cases 3
A Replacing 5r55w transmission, pointers? Transmissions & Transfer Cases 1
M 03 5r55w pump removal Transmissions & Transfer Cases 2
L 5r55w TransGo install P0733 & P0735 Transmissions & Transfer Cases 19
J 5r55w 2002 xlt Transmissions & Transfer Cases 2
J 5r55w Transmissions & Transfer Cases 0
D 5R55W rebuild....will this cover it Transmissions & Transfer Cases 4
M Another 5R55W P0745 thread Transmissions & Transfer Cases 0
B 5r55w thermo bypass Transmissions & Transfer Cases 0
L 5r55w swap to 5r55s Transmissions & Transfer Cases 4
0 5r55w to5r55s swap questions- need info please Transmissions & Transfer Cases 5
C 2002 Ford Explorer 5R55W Transmission Question? Transmissions & Transfer Cases 3
R 5r55w question Transmissions & Transfer Cases 9
E 5R55W- May or may not have a problem Transmissions & Transfer Cases 3
D What years was 5r55w used Transmissions & Transfer Cases 1
C 5r55w shift kit verse shift improver. Transmissions & Transfer Cases 2
R 5r55w intermediate adjuster strut question Transmissions & Transfer Cases 3
S 5R55W is shot; anything else fit? Transmissions & Transfer Cases 1
HiImBrian No 2nd gear 5R55W Transmissions & Transfer Cases 2
Similar threads
