Javier B
- August 5, 2017
- Austin
- 1995 Explorer XLT
Hi Explorer friends,
My 95 XLT 6cyl suddenly started making an alarming crackling sound intermittently from the engine. The best way I can describe this sound is like crackling electricity or a plastic bag stuck in vacuum cleaner. And when I say intermittent, I mean it appears to be entirely random for a few seconds and stops. Any speed, any rpm, even coasting, forward or reverse, with or without bumps or turns, AC on or off. Disappears for a bit, then happens again. Sometimes louder, sometimes more faint. So far it does not seem to happen while in idling or reving in Park. Does not seem to correspond to any change in performance of the car. It began after we had the car sitting in an airport parking lot in 100 degree Texas heat for about a week. Had been running perfectly until then, but within a minute of driving out of the parking lot it started making this bizarre noise off and on. Couldn't figure it out, took it to my mechanic who didn't have a clue and told me to keep driving til something breaks, which doesn't sound particularly encouraging. The car runs fine, but something is clearly wrong. As an aside, it seems to be leaking a small amount of Power Steering fluid, in case this may be related?
I've read on various forums that it could be ball joints or other steering issues, but since the sound does not seem to be in any way related to bumps, turns or speed, that sounds unlikely?
Any ideas welcome. Thanks!
So, an update to the noise:
( I'm still trying to record the sound, but its so sporadic that every time I have my phone out the sound stops)
I mentioned that it makes this sound relatively often when going slowly in reverse. What that sounds like is something like a ratcheting "geiger-counter" sound. Just like going forward, it only lasts about 2 or 3 seconds and stops. But the quality of the sound is a bit different in reverse, and when it happens it's always immediately after I start moving in reverse. I've driven an extra block in reverse and nothing, but those first 3 seconds are closest I've gotten to being able to replicate the noise somewhat consistently. Does this help with ideas?
UPDATE: AUDIO FILE OF SOUND IN REVERSE ATTACHED.
Update# 3: It seems like it's in the transfer case. :-( pulling it out and maybe putting in a refurb. Weird that it was so intermittent. Will confirm this later if issue is solved.
