08EddieCA
- March 31, 2016
- Location
- CA
- Los Angeles, CA
- 08 & 03 X (Eddie B & XLS)
Hello,
I live in a hilly area of Los Angeles. I'm sure driving down long hills generates a lot of heat in the front (and rear) pads.
Last week I was cut off on the 405 freeway causing me to apply as much pressure on the brake pedal as I was able to muster. The abs went off and I avoided running into a POS that cut me offf.
When I pulled off the pads there was a crack running through the pad (north to south) on both pads on both sides - DR and PS.
The brake pads have about 20,000 miles on them. Due to the crack, I'm going to replace the pads with a higher quality Raybestos pads EHT1158H set.
Has anyone else run into cracked brake pads? I bed in the pads exactly as the directions told me to. A few thousand mils ago, when I was replacing the wheel bearings, the pads looked normal.
Could a high speed lock up (with the abs working perfectly) cause the pads to develop a heat crack? The calipers are brand new Motorcraft calipers. The rotors are new, slotted Brembos. Break fluid is changed every year.
Thanks for your help.
