Cragar wheels with 265/75/16..what size rims? Rubbing issues? | Ford Explorer - Ford Ranger Forums - Serious Explorations
buubba429x
Stratford, CT
2003 Explorer
I need to get new tires and I plan on getting some all-terrains in 265/75/16 size with no lift on my 2003 Explorer. I also plan on mounting them on black 16x7 (4" backspacing, 0 offset ) or 16x8 (5" backspacing, +12mm offset) Cragar Soft 8 rims. After having a lifted Jeep and seeing the issues it can cause long term on other parts of the truck, I will not be lifting the Explorer at any point. I like the squat, wide look anyways and I won't be doing much offroading. With that said, which size rim should I go with? I do want a wider stance, however, I don't want the combination of wide wheels and fatter tires to cause rubbing on the fender. I don't mind some minor trimming of the fender's inside plastic, but I dont want to start hacking any visible parts of the fenders. I searched, but could not come up with any definitive answers. Any advice, experiences, and/or pictures of this setup are greatly appreciated.
Wills05xlt4x4
Ashland Va
2005 Xlt 4x4
i would reccomend either a 1.5 body lift or maybe go with a 255 especially if you dont have the tow package tto help reduce strain on trans with the lower gears
they will fit but everyone rubs in minor places which vary truck to truck
buubba429x
Stratford, CT
2003 Explorer
I do have the tow package. I have a 2003 Explorer XLT with the NBX package. I have already stated I will not be doing a lift at any point. Just a simple rim and tire replacement.
armysoldier30263
Shaw AFB, SC
05 BLACK 4.0 XLT
im running 255/75-17 bfg mud terrains with a 2.25/1.75 btf lift and i rub at full lock ... stock wheels
xplorerguru
2005 explorer
Im running 265/75/16 on my 05 with NO lift and cragar soft 8's 16x8 NO RUB AT ALL
Cozmik
Kitchener, Ontario
'07 Jeep Sahara Unlimited
I had 2 different styles of 265/75R16's on my 05. First were DC Mud Country's, and then BFG AT/KO's. NO lift. At FULL steering lock, I sometimes had a tiny bit of rubbing on the inside plastic fender liner, and mostly in reverse. It can be fixed with a couple of zip ties but I couldn't be bothered as it wasn't all the time or bad enough to worry about.
Cozmik
Kitchener, Ontario
Dick Cepek Mud Country's, 265/75R16;
