Well, I thought I had the X all ready for truckhaven.. On my test drive (didn't get far) things went awry. Apparently I got distracted and thought I installed a bolt when I didn't.. I must have had a brain fart....
After about 1 hour of wrenching the front end now looks like this.
Front end, apart again by maniak_az, on Flickr
And inside the Driver side beam had this..
Dana 35 trac lok damage-1 by maniak_az, on Flickr
Here is what I saw inside the diff.
Dana 35 trac lok damage-2 by maniak_az, on Flickr
From what I can tell, the case and carrier and even all the gears are fine.
I looked in the box of the old diff parts and viola, there is the cross shaft retaining bolt.. It would have worked so much better if I installed it "in" the diff.
The issue now is to find a Dana 35 trac lok cross shaft. The cross shaft from the factory open diff isn't the same size..
~Mark
~Mark
