    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership!
Crankcase ventilation system disconnected?
TXExplrPlt17
2017 Explorer Platinum
Went to my local shop and they ran diagnostics. Said it would be $300 and three hours of labor to replace the PCV valve. Did a YouTube search and got pissed and left: 3 minute repair, including dropping the wrench. Got an OBD reader and now it's coding for the picture below. Can anybody help me with this?
I called the manager of the shop and asked him why they would do that to me since I've been going there for 10 years. 'I'll call you by tomorrow morning.' I hope he does and I hope they have a good explanation for why they would pull that.
MakinJeepsWeep!
Polk County Texas
96 Explorer 5.0L AWD
Callsign
Big Red
If you fixed the issue did you clear the codes or unhook the battery and let it know its fixed.
TXExplrPlt17
I am going to post pics of this once everything is done this weekend. So far, I've done the following:
1. 5 Star Tune
2. Cup holder, console, etc. liner kit (17 pieces) - black/red so really makes the interior pop
3. PlastiDip all chrome
4. Off-road high beam bulbs
5. LED interior bulbs
6. Aftermarket stereo system: all new speakers, amps, sub, etc.
Can't remember what else because it came so nicely equipped.
runningonfords
Detroit, Michigan
2014 Explorer XLT RRM
Fixed it and it runs like new. Thank you very much! Can't wait to install new gapped plugs tomorrow and reinstall tune.
Plugs are great, makes a big noticeable difference. Get the nice platinum ones. If you're gonna do them, clean your throttle body too at the same time, just a couple more steps if that, and a bottle of carb cleaner. Here's a video. And a Second Video. Both are important. Even a slight bit of colored gum in there really affects airflow into the intake. Gotta disconnect the battery, drain system residual current too, and relearn the shift points, but what a difference for a meager effort.
TXExplrPlt17
Thank you very much for this. I have the platinum plugs, and I'm going to gap them per the tuner's suggestion. Have had them for a while but not able to install until now because of broken ribs. One question: carb cleaner for injected vehicle? Or is it just using it as a cleaner?
runningonfords
Detroit, Michigan
You'll have the throttle body entirely off the car, so there's that, also be safe cause it can chop fingers. Usually the cleaning product is called "carb, choke, and throttle body cleaner" in a spray can. You should get a new throttle body gasket as well.
MakinJeepsWeep!
Polk County Texas
Callsign
Big Red
Sorry i took so long to get back to you my Mounty decided it was time for some tlc so i have been busy with it. Glad that got you going. I tell you what i do. Anything im going to do to the trucks that will take longer than a hour and is not electrical item i take out the battery and throw it on the charger, keeps the battery higher than your alt can using a trickle charge. You can always give your teminals a quick scrub too. Doesnt take long and it really helps. Now if what your doing is electrical always unhook the battery. Some computers do pick stuff up some dont just how it is. My B series truck that computer picks up everything my 96 X nd 06 Mounty do not. Any ways Glad you got it going!!!
TXExplrPlt17
Check Engine light on again. Ran diagnostic, same code popping up. Anybody have a suggestion? My understanding is that there are 2 PCV valves. . .could the other one need replacing? As you can tell, I have zero experience with this stuff. Thank you ahead of time.
MakinJeepsWeep!
Polk County Texas
Callsign
Big Red
What year motor ect is this again?
MakinJeepsWeep!
Polk County Texas
Callsign
Big Red
Sounds good, let me know what they say please!
TXExplrPlt17
Okay, so now I really need your help. Both PCV valves have been replaced (one by me, one by dealership) and it's STILL throwing the same code. Wth. Any ideas, team? I'm still baffled that they didn't look at the check engine light still on when it left. I asked and he said 'Oh, we only do the work that you ask us to do.' I get that, but a Ford vehicle is leaving your Ford dealership with the Check Engine light on, bruh. . .might want to check that or at least mention it to me before I Uber up there to pick it up.
