spencer morris
- November 13, 2011
- brunswick,Ga
- 94 explorer limited
wat up everybody i have a 94 explorer and i seem to have a problem with it cranking. sometimes in the morning i have to turn the key 3 or 4 time for it to start and when you drive for a min it doesen't want to crank back up untile a hour or 2 later and sometimes when it does it does a sputter type of crank and doesen't want to idle for some reason. I have changed spark plugs, fuel pump & fuel filter, the coil is new, the starter, crank positioning sensor, battery, purge valve, and checked vacume lines, I like the truck but starting to feel like its not worth it. any tips will help.
