Kathlene
- December 17, 2001
- san diego, calif
- 97 explorer xlt
97 xlt, this is first problem since purchased used. has 85,000 mi now.
Went to start this am, cranked over just fine but would not start. Hubby checked manually for fuel pressure at schrader (sp?) valve on fuel line assembly, got good fuel pressure.
Checked relays for cleaniness and tightness in fuse box, under hood, check all visible electrical connections.
Any suggestions and or help?? only good thing, i missed a day of work.
I've edited this to add...
where is this pump relay switch located that i am reading so much about?
and crank shaft relay??
Thanks so much in advance!!
