Exp98
- August 31, 2020
- USA
- 98 XLT SOHC
Hello,
I recently replaced my primary guides and tensioners on my SOHC. However, I just found out from some more reading, that there have been issues with crankshafts breaking? As far as I have read, there is no consensus as to wether it is caused by improper balancer installation or a manufacturing defect, or just luck. Also, was this the proper way to reinstall by balancer? 1. Line up keyway 2. Tap in with mallet 3. Start by turning by hand to engage threads fully 4. tighten with impact 5. back off slightly. 6. torque to 80 lb ft and 1/2 turn. Assuming the procedure was correct, what are the chances of crank failure? Also, is there any preventative maintenance that should be done as I crossed 300k not too long ago. (I do oil every 3.5 Mobil Full Syn HM, Fram Xtra filter, fuel filter every 80, plugs every 70, front/rear diffs every 30-35, trans fluid every 25, trans filter every 100, hydraulic tensioners every 100, coolant every 40, decarbonization every oil change) I probably forgot something lol Thank you very much!
Regards,
Exp98
Regards,
Exp98
