Well, I usually keep them around 38. Is that considered overpressured?
38 PSI seems somewhat high. 30-32 I would think would be enough.
The factory documentation for my 2000 Sport recommends 26psi for all 4 tires. sounded a bit low to me, but it rode fine. now that i'm running a shorter and wider tire size i usually run around 30psi
EDIT: also, i agree with the softer shocks equaling better ride quality, i'm no expert, and if anyone here IS an expert please correct any of my misconceptions, but here's the way i understand it:
softer shocks = smoother ride, smoother reaction to small road obstacles, slower and more exaggerated steering reaction, but maybe a little more bouncing because the shocks dont dampen as much spring movement, less control and more body roll/pitch while cornering, braking and accelerating
harder shocks = rougher ride, more abrupt reaction to road obstacles, quicker and more precise steering reaction, less bouncing because the shocks dampen more spring movement, more control and less body roll/pitch while cornering, braking and accelerating
softer springs = smoother ride (to a degree until suspension bottoms out), smoother reaction to small road obstacles, may bottom out on larger obstacles, can be dangerous under heavy loads/towing due to lack of control, can be dangerous when coupled with worn out/excessively soft shocks because the body rolls/pitches to an extreme degree if emergency maneuvers are not performed properly (thus the rollover hazard of our top-heavy trucks)
harder springs = stiffer ride, more abrupt reaction to road obstacles, respond more naturally under heavy loads/towing, can be squirrelly, jittery or throw the vehicle around suddenly when encountering road obstacles at speed if springs and shocks are too hard for vehicle application
suspension tuning is all about balancing what you want, with what your vehicle needs and then factoring in practicality
