SilverSPL
- January 31, 2007
- blah
Ok heres my first how to, I did this back in june and someone on here suggested I do a writeup on how I did it so here it is. Bear with me it's been awhile sice i did it so I forget a couple of thigs.
Well this is the final product, I'll take you through all the steps to make this.
Started out by removing the center console, it's held in by clips and one screw under the black ruber. Then I taped off the area where I want to make the pod with 3m Painters tape. Then rub mold release wax ontop of the tape.
I then drew out some guide lines onto the tape with a Black sharpie that will transfer to the fiberglass. Then laid down 5 layers of glass
Pulled it out and trimmed off the excess and cut out the bottom
Then out of 1/8 inch wood (similar to mdf or is, not sure) I cut our the openings I wanted for the gagues and switches. Then hot glued them to wooden sticks in place
wrapped in cloth and held by adhesive spray glue, then cover the appropriate areas with resin. then once hardened trimmed away unneeded cloth
