Explorer Power
- February 10, 2009
- The Netherlands
- '99 4.0 V6 SOHC
Hi there,
Since our 4.0 Sohc v6 engines dont like freeflowing exhaust systems with big pipe diameters and need backpressure to produce low end torque, true duals seems to be out of the question, almost all low end torque seems to be lost...
So what exhaust setup for our 4.0 Sohc engines will produce the most low - mid range torque...? Without losing top end horsepower...?
That is the question. :scratch:
So the pipes from the back of the headers to the cat's, these are about 2 inches diameter stock, i think.
Will it have any use to replace these?
Then the cat's... These will be removed of course. :
Should the pipes then be brought togheter with an Y- pipe? or use a dual in muffler?
Wich muffler should best be used?
If dual endpipes are preferred, wich diameter should be used? 2,5 inch? or even smaller?
Thanks in advance.
Thanks in advance.
