smiley1
- February 17, 2003
- central coast, Ca
- 1998 XLT V8 AWD
I wanted to share with you folks what I did. Some of you may know from my past posts that I don’t like K&N air filters for daily drivers as they tend to foul MAF sensors even when properly maintained. My goal here was to increase flow while utilizing the superior filtration properties of a conventional paper filter.
*Note: This cone style paper filter replaced my flat panel K&N filter.
I used some Lexan and a STP air filter #SA9345 (same number for Fram). I also used 3" ABS plastic tubing.
I removed the entire air box assembly.
I took a short piece of 3" ABS and glued it to the back of a small piece of Lexan using PVC pipe glue. I marked the holes for the factory MAF. I drilled the holes for the MAF bolt holes and cut out the ID of where the tube met the flat panel. I bolted my new MAF adapter to the MAF using the stock gasket. I installed the New paper air filter which just fits over the ABS adapter.
I used cardboard as templates to shape a barrier to the heat associated with the heat of the engine.
Utilizing the cardboard templates I cut two pieces of Lexan which adequately shielded the heat of the engine from the filter element. I will add a heat reflective product at a later time to further insulate the heat.
RESULT: Excellent throttle response. I noticed the nose end of the X perk up a bit more on WOT. Seat of the pants feel could be in my head but seems to have increased noticeably. I will be testing MPG gains as well, if any.
COST: 4.00 for small section of ABS, 14.00 for filter, and 12.00 for more Lexan than you will ever need. Total is approximately 30.00
I have uploaded the pics to my account but they may not show up just yet. Even so... here is the link:
Click on the slide show
http://www.imagestation.com/album/?id=2115876598
If you have trouble seeing the pics, PM me and I can Email them to you.
-Rob
-Rob
