We built some jigs, we built some beams, we realized we missed one dimension when constructing our jigs, you must think of the beam as a triangle from pivot to BOTH ball joints. Simply moving the pivot point upwards for lift will shorten your track width = a no no, so you must build in some increased width to your newly cut beam so you dont come up short.
We scrapped one set of beams and then we had our jigs correct and built 3 more sets.
I run 3" duff drop brackets at the pivot (actual 2" drop I believe)
I run a 3" cut and turn in the beam and a 2" extended track width per beam. I use a 6" skyjacker coil (for now) with an F-150 spring seat (another 1-1/2" for coil sag).
I have the stupidrunner steering along with Skyjacker radius arms (for now)
we had to build a custom outer axleshaft for the passenger side to make up for the new increased track width.
I bought a spicer dana 44 shaft BLANK, had it cut to length and splined for the dana 35 slip yoke, it works perfect.
Here are some spy pics to give you a simple idea of a simple jig that works very well
If I was to do it over again I would do a combo cut and turn in the beam on the pivot side and a ball joint turn to account for more lift, a bit more bump travel, a bit more ground clearance, and if you move the ball joints out the correct amount you can run dana 44 outer shafts and gain another 8" of track width. Now you are in the 20" wheel travel range with good radius arms.... it gets expensive real quick, its never enough..... swing set steering would be next, or a good clean simple inverted Y setup like Autofab uses
You may also consider a modified dana 44 TTB swap, this has alot of benefits right out of the box, if you can build the beams or just order them from Autofab LOL
dana 44 ttb
stronger ball joints
better wheel bearing spacing
stronger hubs
bigger brakes
and 19" of wheel travel ( cheating 8" of track width but who cares!)
4x4 IFS + long travel = $$$$$$$ no matter how you swing it, I went on the cheap and with a big learning curve, my front end runs locked 35's and has about 12" of useable wheel travel (maybe 14 on a good day, still too much camber/toe change for my taste) it works well for me but I want more... of course
