If it’s bent it’s too large to fit out. If it happened when driving I’d turn it into my insurance as an accident.I can understand if it's bent it would cause damage coming out but it still should be able to be removed.
What would bend it inside the PTU and transmission? I have no Crack in either casings. No signs of any leaking. If it had enough force to bend axel I should see signs of somethingIf it’s bent it’s too large to fit out. If it happened when driving I’d turn it into my insurance as an accident.
They’ll probably claim lack of maintenance, though.
Okay. Then why won’t it come out? Maybe you’ve broken something inside you can’t see. Probably time to torch the axle off and drop the PTU.What would bend it inside the PTU and transmission? I have no Crack in either casings. No signs of any leaking. If it had enough force to bend axel I should see signs of something
I'm at something the technician did when he had the Axel out last.Okay. Then why won’t it come out? Maybe you’ve broken something inside you can’t see. Probably time to torch the axle off and drop the PTU.
when was that service with that tech? did they replace the axle at that time?I'm at something the technician did when he had the Axel out last.
So you think it’s more likely someone else damaged it on install, and not you driving it until the front end literally fell apart?I'm at something the technician did when he had the Axel out last.
Every technician I have spoken with was persistent that it had ring. I have been trying to eliminate anything thing I can. The technician had that axel out to do the repairs for the transmission. If he read the wrong instructions and placed a ring on it because the instructions told him so. The control arm casting broke. Not the ball joint or any bushing. A casted piece of aluminum. I could see bushing and bearings brake but not the control arm casting. Pulled out of parking lot turned left the car jerked from the control arm breaking and car was stopped. Even with the control arm breaking the cv shaft pulled apart at the outside joint. I dont see enough force for the Axel being damaged enough for it not to be able to be removedSo you think it’s more likely someone else damaged it on install, and not you driving it until the front end literally fell apart?
What could they have possibly done? There’s nothing that holds it in. It’s not like they messed up a clip, or fastener. It doesn’t screw in.
Oct 2020. No axel was not replacedwhen was that service with that tech? did they replace the axle at that time?
