- March 16, 2013
- Woodstock, GA
- 04 Ford Explorer 4.6l
So I pulled the passenger side cylinder head on my 2003 4.6 L which of course promply filled three of the cylinders with anti-freeze.
Cylinder one was at top dead center, cylinder two, down a little bit, cylinder three down farther, cylinder four presumably down to the bottom.
Four hours later I went to remove the anti-freeze from the cylinders and only cylinders two and three still had antifreeze. Cylinder number four was completely "dry".
I'm guessing this tells me that I have bad rings in cylinder number four. I thought I had a blown head gasket on both sides which I still believe I did as anti-freeze was going out the exhaust, but I'm wondering if I don't have bad rings and one piston on the other side as well.
The engine has 200,000 miles on it, should I junk the engine or pull it and put new rings on the pistons and see how it goes?
Bought car for $400. Was hoping to keep the engine as a spare.
