jelkins
- September 11, 2010
- fayetteville north carolina
- 91 xlt 4x4 & 02 2wd
cylinder 5 & 6 !!!!! (SOLVED)
so i have a couple of problems that might be tied to eachother im going to start at the beginning.....
ok so i bought an engine from the local pull a part and had it in, in less than eight hours started right up good great! i was happy considering the fact that it was a shot in the dark. now the problems there is a loud ticking on the passenger side a local mech i talked to said it was just a lifter cool no problem ok it also has a very noticable miss so what i did was sprayed some starter fluid around all the vacuume lines and upper intake there wasnt any noticable changes so im guessing that its not a vacuume leak so i started to pull spark plug wires i started at cyl 6,5,4,3,2,1
in cyl 6 and 5 there wasn't any noticable change but there was spark to the plugs for sure and one by one the rest of the plugs bout killed the engine which leaves me to believe that i have a problem between 5 & 6 so that being said could it be a fuel problem??? where do i start. i can change out parts and engines all day but when it comes to troubleshooting ya im more of a generator mech/ networking guy lol any help is great.
first idea was to take the whole upper and lower intake from the old engine w/ injectors i know that are good and just swap them out, and see if the injectors are my problem. my issues are more with the electrical side.
(my reasoning i painted the upper and lower intake black, block and heads black, motor mounts red valve covers red pully's red and the oil pan red, just need to put the painted intake and fuel rail in with the old injectors)
my plans are the get this motor running good enough to drive for now as soon as taxes roll around im going to rebuild the old engine in which my piston rings were bad on. like the works block and heads new every thing just have to wait on the money
