jhanson25
- March 10, 2010
- 1996 XLT
I picked up a 96 XLT the other day and cylinder 5 is misfiring. I was told it could be anything from a plug to a plug wire or coil pack. Is there anything else in the 4.0 that would lead to this issue that may be common? It's also throwing a code saying the coolant is not getting up to temp. I can also tell its not by the gauge. Any ideas? The drivers window will not roll down... figured it was a motor..... but all 3 other windows go down from the drivers control panel, but not when I use their own switches. I figured the switches went out. The window lock was not turned on when I tried this as well. Thanks!!!!
