YBCold
- January 4, 2009
- Las Vegas NV
- 91 ×∟┬
right so i have 3 seperate instructions about torqueing the cylinder heads and lower intake. but i was doing a dry run today and i noticed my haynes manual says to put RTV sealant around the water jacket ports.
it then says not to put RTV sealant on the head gaskets but the picture shows the block with RTV sealant around the water jacket ports which couldnt be possible unless u put the RTV then the head gasket. so should i put RTV sealant on all water jacket ports, then cylinder head, then lower intake with RTV at mating corners?
