compleckz
- March 10, 2006
- Charlemont MA
- 97 Ranger Locked + Lifted
so for the past 6 months maybe, the truck on cold start has ran like it was misfiring for like maybe 20 seconds, if i revved it up a bit, it would go away quicker. it never did this again till it sat for over ~8hours.
today on my way home from a friends (700lb wheeler in the bed), it started running rough, stumbling, and i could hear like backfires in the intake when i got on the gas (i have a cowl-snorkel, so it was quite easy to hear)..
i was a mile from home, and when i arrived i unloaded the wheeler, checked over the engine, and couldnt find any apparent problems with the plug wires etc.. (they are 6-12 months old, along with the plugs)..
no CEL or codes, so i took it for a rip up the road and matted it (may not have been smart, but..) i got the CEL on, and got some codes, p0300 which is random cylinder misfire, and p0301 and po304, which are cylinders 1 and 4 misfire.
the only thing i have done is replace the coil (figured it was a good first step) and it did not fix the problem..
like i said before it did the same thing on cold start but very briefly, hopefully the sequence of events will enable someone to identify the part that has failed, so i dont go replacing new(ish) wires/plugs.. or more unnecessary stuff..
the 2nd cat was glowing red when i last drove it, and i could smell sulfur, but this is probably caused BY the misfire, not CAUSING the misfire.. but i'm not 100% sure of that..
this is a 97 OHV 4.0, 110k miles. thanks guys!
