D30 or D44? | Ford Explorer Forums - Serious Explorations
D30 or D44?
321Explorer
Satellite Beach, Florida
1998 2wd Explorer Sport
I am going to do a Solid axel swap on my 2wd and then convert it 4 wd afterwards, what should i use on the front? D30 or D44, it will be fitting at least 37's most likely bigger. Thanks in advance.
D44.
D60
D44 and 3" wheel spacers for the rear
I see your 3" wheel spacers and I raise you 2" spacers.. you calling? wait nevermind, i FOLD! :D
If you intend on running tires larger than 37s on an Explorer I would say D60. If you don't you're really going to be pushing it. You may end up with more busted u-joints, knuckles etc than you would like. That's IF you wheel it.
If it's just for show the D-44 would be fine.
D30 the max tire size would be a 33" if you wheel it hard and a 35" if its for show/light whelling...im agreing with the D60 or D44
hahaha
Jus go with D 1000's and get it over with
