CBII
- November 4, 2004
- Edmonton, Alberta Canada
- 91 XLT
Just thought I'd share my D35 c-clip eliminator with you guys. If you've ever broken an inner stub shaft on the passenger side this could save you a shi* load of work. I just finished installing front Auburn ECTED locker into my Bronco II's D35 and figure way not save the hassle and just get rid of the c-clip now. I researched a lot and talked to a lot of people which helped me out a ton. But I'll save you or anyone else thinking about this the time and effort by posting what I did and how I did it. If you have questions just ask and I'll help you out as best I can.
Ok the basic idea here is to replace the c-clip that holds the inner stub axle shaft from falling out of the front pumpkin. If you ever have to do this job it means an almost full tear down of your front axle just to get the pumpkin out. Take it from me it ain't that fun in a shop let alone on a muddy trail somewhere in bumfawk nowhere.
So after much consultation and measuring and re-measuring I ordered custom coil springs from a local spring shop. They gave me 3 of them but I only needed one. The Garage tests worked great and my bro (who's pushing 300lbs had to put a lot of effort to hold the axle shaft in place while I made sure everything was buttoned up and in place).
Here's my report from the weekend of wheeling.
I removed the sway bar so that I could maximize my flex in the front.
So that now leads to the c-clip eliminator. With the sway bar off and allowing the TTB to fully flex with the extended radius arms I figure that that would really test the set. All I have to say is WOW...I had crazy flex like never before and not once did the inner stub shaft coming out of the pumpkin become an issue. I'm very pleased with the set up...a little more testing and I'd pretty much call it a great mod for locked or stock front ends.
