Dammit Rick! I bought another one! | Page 2 | Ford Explorer - Ford Ranger Forums - Serious Explorations
This is all @Rick fault. I bought another Explorer today, but before you all jump to conclusions and calling me Zukman ( :p ), here me out...
Why did I buy Another Explorer? Well I as some you may know, I ordered a 2019 Ranger, but it will not be here for a few months and I need to dump my Focus ST, but I still need a DD in between. So what do I do? Buy a cheap reliable truck that I know well.
Now the fun part, look at what I found.:D
1997 Ford Explorer XL 2wd
4.0 OHV
5-Speed Manual (yes a 4dr Manual)
3.27 gears
A/C
165k
No really that's it. It super bare bones, Manual Everything! Manual Windows, Manual Mirrors, Manual Door Locks. Vinyl Seats. Runs really smooth:thumbsup:
It's in crazy good condition, super clean in and out. Has a few minor thing to fix, but nothing crazy.
Will be available for sale in 6 months or less if anyone is interested.
Mbrooks420
High Voltage.
1998 Mountaineer AWD
Sure you ain’t rocking one of dem whistle tips?
Stic-o
Elite Movie Star
Lake View Terrace, CA
'91 Navajo '99 X '19 Rngr
So I've driving it for a few weeks now, and it seems to be good, getting around 16-17mpg, but that me sitting in LA traffic for half my commute.:( It has been fun to run the gears out to 2500rpm+ to get it in it's torque band. If I was going to keep it as a commuter I'd toss some newer explorer 20" rims on it with 4.10's a limited slip and lower it down a bit. It would be fun:burnout:
Which brings up the speedometer working only part of the time. I've figured out it's heat related. When it's cool like in the morning, it works. If the truck has been sitting closed up in the sun, it doesn't. In the evening before the sun sets, the speedometer works again, but withing a few minutes of turning on the headlights, the cluster gets warm, and I lose the speedometer. Same on a warm day, if I run the A/C for a while, I'll gain the speedometer back once the cab cools off enough.
So this tells me there is a resistor or something in the cluster that is having a issue. How to track it down and fix it, I have no clue, it easier just to swap the thing out. But I thought I would document this for anyone in the future with this issue.
donalds
Location
Stem
Nc
1999 ford explorer sohc
Reflow the speedo terminals with solder and clean any corrosion off with electronic cleaner
Mine did this
I would tap the dash above and all was well for a bit
Worth a look
Stic-o
Elite Movie Star
Did you ever fix the temperature gauge issue?
Swapped out the gauge cluster. Didn't change the gauge reading. It's just measures low, probably a sensor thing. I confirmed with forscan that it's at the right temperature. May swap out the sensor, or just know that where it should be.
Speedometer works now though:thumbsup:
Stic-o
Elite Movie Star
Planning to swap out the sensor now, as it now goes up and down all the time. It's like a dam yo-yo. Truck runs fine though, and is getting a solid 17mpg. That's with my LA traffic and some open freeway.
Stic-o
Elite Movie Star
Ugh...just pulled in the driveway with water leaking everywhere under the front of the motor. Looks like the water pump just gave up the ghost. Could explain the random temp gauge.:rolleyes:
Stic-o
Elite Movie Star
Water pump replaced, and also swapped out the temp sensor and the fuel filter. Truck runs awesome now:thumbsup:
Mbrooks420
High Voltage.
Good for another 100,000.
Stic-o
Elite Movie Star
Yeap, just need to find a future owner, because I'll be putting it up for sale in January, once my new Ranger gets here.
Stic-o
Elite Movie Star
So....good news and bad news....:frown:
I keep getting a check engine light, it just will not go away. Truck runs great, but the stupid light just keeps coming back, after I think I've solved it. Well I figured it out now. I've been thinking it's a vacuum line some where. So I started looking and then I found the issue......then it became like stepping on thin ice. All the lines just kept breaking, it's crazy! So what I thought was a simple fix has turned into redoing the whole vacuum system possibly:shifty:
I was going to pull the lines off JP, so I could drive to work tomorrow, but in fear of breaking one of JP's lines, I'll just drive it tomorrow, since I still haven't fixed the f250 either yet :dunno:
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Callsign
FOURTEN
1996 vacuum lines are getting older!!
What is the code you keep getting?
Stic-o
Elite Movie Star
The usual P0171 & P0174 twins:rolleyes: There was already some lines replaced before, early this year according to the dating on the tubing.
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
I just saw this thread. No one will call you Zukman because most of your stuff runs. Well, maybe 50% runs. OK, Son of Zukman….
If I had more room that wasn't in view of the house, I would have purchased a few more first gen's for parts just because. Maybe I could talk my mom into letting me store a couple in her RV garage.....Hmmmmm
Stic-o
Elite Movie Star
Some 5/32nd tubing and fuel pump and we're at 100% (Navajo doesn't count, it's a work in progress)
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
Callsign
FOURTEN
intake plenum rings?
Both banks lean, ethanol fuel, 1997 was a long time ago = new O ring time? Or did you already do those?
Get the big green O ring for the EGR tube also
Stic-o
Elite Movie Star
Haven't done them, but I'm pretty sure it's the vacuum lines causing the issue, or what's left if them. I just need this thing to hold together another 90 days or so. Then it's out of here..
Stic-o
Elite Movie Star
75% now;)
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
Callsign
FOURTEN
I still say its intake gaskets :)
With the upper plenum off its really easy to fix any broken vacuum lines
Staying tuned
