Blackdog
- August 31, 2006
- Zillah Washington
- 2004 F-150, 2006 Ranger
I have a 97 Ranger 4X4. I pulled the Dana 28, and replaced it with a Dana 35. The Dana 35 has new 4:88 gears, bearings and seals. I'm using the Dana 35 axles that were with the differential.
When I was assembling the drivers side hub I found I could not install the spacer and "C" clip on the axle end because the axle didn't stick out far enough. I tried prying the axle out a little but it was out all the way.
Why won't the axle protrude out far enough for the spacer and clip? The inside end of the axle is held in by another "C" clip in the diff. I'm thinking that the gear installer moved the gear assembly while shimming it, the 4:88 gear is much thicker than the original 3:73.
Any ideas?
Any ideas?
