SteveVB
- July 8, 1999
- Gaithersburg, Maryland
- 04 Rubicon w/stuff
Anyone set up their Dana 35? I am having a problem getting a pinion shim. The manual calls for shim placement( actually a selective fit oil slinger ) between the pinion head and the bearing, but the shims that I got ( I ordered from two seperate places and they sent me the same set odf shims) are much too big for that, but they look like they would go behind the race? Anyone have any insight for me?.
Thought Id add that the gears Im putting in are 0 and the existing are marked +1 so Im looking to add .001" do you think I should assemble it and check the pattern first on the chance that they will be OK?
