Dana 44 carrier ? | Ford Explorer - Ford Ranger Forums - Serious Explorations
Dana 44 carrier ?
-=DaemoN=-
The Netherlands
Rigless!
I found a HP dana 44 with 3.50 gear ratio and my questions is... would I need a different carrier if I replace the current gears to a lower(higher#) ratio? Thanks in advance.
Join the Elite Explorers $20 each year.
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
Dannyboy
Other Make & Models Mod
Moderator Emeritus
43°48′48″N 91°13′59″W
91 4 do'
Dameon I have no clue about this, but if you go solid axle I would be interested in a couple of pieces of your salvaged skyjacker lift. Mainly the 6" coils( I'm pretty sure you wont be able to reuse these) and extended radius arms if you have them, otherwise the brackets.
-=DaemoN=-
The Netherlands
Rigless!
Dannyboy- it's gonna be awhile till I put the axle in.
For the parts, I don't have the extended radius arms just the drop brackets.
I thought you already have 6" of lift?
james t
Moderator Emeritus
Texarkana AR/TX
94 SAS sport
no, you should not need a new carrier. i just put 4:56's in my early bronco with 44 front. it had 3:50's stock, and we used the same carrier.
-=DaemoN=-
The Netherlands
Rigless!
Thanks for the info james T.
Dannyboy
Moderator Emeritus
91 4 do'
Umm I have a 4" lift with spacers, but am putting skyjacker brackets under it so I don't have to run bumpstops like I did with the trailmaster brackets. If I sell the kit it would be hard for someone to find just the radius drop brackets unless someone on the board had a set for sale(like you would) as well as I may buy 6" springs and run them with spacers maybe. Right now I plan on running 5.5-6" suspension lift off of the 4" lift point on my jacker brackets. This seems to hold alaignment well (better than when I didn't have the spacers, it was tooo / \ for my liking. PM XJ2Extreme or maybe I'll get him to speak up. I know he bought Dana 44s, shortened one side and is running 5.13 gears and he had no clue what ratio was in them when he bought it.
Brian1
Albuquerque, NM
1991 XLT
Callsign
KG5BAQ
Most dana 44's have the carrier break at 3.93 so I would think you would need one for the 4 series gears. The carrier you have now is good only up to 3.93 unless you have a special type of carrier (never heard of one before)
-=DaemoN=-
The Netherlands
Rigless!
That's what I thought Brian. I was looking for 4.56 gears and ran across the 3.93-up carriers and 3.93-down carriers. I guess, I'll have to make the guy installing the gears take a look at it. He's also getting the same '78 HP dana 44 put on his cherokee but with 4.88's.
james t
Moderator Emeritus
Texarkana AR/TX
94 SAS sport
well, i guess they make 4:56's for the 3 series carrier, maybe? i know for i fact i had 3:50's stock, and i know for a fact we used the same carrier (i helped with the install.) maybe they make 56's for both carriers. you know, thinner/thicker ring gear to help offset carrier size.
