fordpickupman
- March 18, 2011
- Cascade, ID
94 XLT
71 F250 Fummins
Alright, I've been researching this for about a year off and on. It appears that there are several ways to get the longer spindles and bigger brakes of the Dana 44.
I read one on Ranger Station where the guy had used the Dana 35 knuckles with Chevy Dana 44 spindles out including the Chevy brakes. Has anyone used the late '70s Ford Dana 44 spindles out including the Ford brakes? The Chevy option requires removing the caliper ears from the Dana 35 knuckles. I assume the Ford option would require the same process.
However I like the idea of the Dana 44 TTB knuckles because of the bigger ball joints. Is this even an issue with 35" tires? I have read where special camber adjusters are needed to run the Dana 44 upper ball joints in the Dana 35 beam. But I've read where some guys install the Dana 35 upper ball joint into the Dana 44 knuckle, or just use the Dana 44 camber adjuster (I assume they are using the pinch bolt to close up the gap). It seems like most of the write ups gloss over the upper ball joint detail of the knuckle swap.
