Dark Car - Disable? | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership!
    If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
Dark Car - Disable?
Pete Adams
Ball Ground, GA
2018 Explorer PIU
Callsign
K4PRA
I went out last night to check out the lighting on my new 18 PIU and one of the first thing I noticed was that the interior lights did not go on when the doors opened. I'm familiar with the option but can't see how to enable the interior lights. I did some searching but it seems everyone wants to turn them off.
I looked in the manual and it looks like it's an option to change but I don't see it.
Thanks
BTW I'm really impressed with the spotlight. Man that spotlight is bright, throws a tight bright white beam 100's of feet.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
I'm guessing the PIU must be different in that regard as with the retail version I believe the feature can only be enabled/disabled with Forscan. There is no setting for it otherwise and there is no mention of "Dark Car" in the Manual.
Also, time to update your profile to add the PIU.:)
blob19
Midwest
2016 Interceptor Utility
If you don't have the option in the instrument cluster like this youtube.com/watch?v=gPl1L4TpQrg#t=1m26s then it's probably disabled through the BCM. Should be:
—Dark Mode 16-18MY BCM 726-32-01 xxxx x*xx xxzz 0=Disabled, 1=Enabled
per FORScan 2011-2018 Explorers
KayGee
Farmington, MI
'16 & '17 PIU
To the best of my knowledge, you can set it up either way in the PIU - on or off with Forscan or changeable in IPC menu.
2016-18 Police Utility Forscan Settings has some Forscan changes that work - not sure why the other sheets don't reference the IPC change. May as well just add the IPC control so it's there and you can use the feature whenever you want.
