Dash dimmer loose. | Ford Explorer - Ford Ranger Forums - Serious Explorations
Dash dimmer loose.
eagleteam
99XLT
Suddenly, and with for no apparent reason, the dash light rotary wheel dimmer switch assembly released from its attachment and is not loose behind the dash. Can anyone comment on how to re-attach this assembly? Do I get at it from below, or do I remove the instrument cluster? I have removed the plates below, but the switch has an enclosure around it so I cannot see or feel the method of attachment.
Does anyone know a good solution on how to replace Ford design engineers? Thank you, any help will be appreciated.
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
