jsblack14208
- March 12, 2011
- Ridgefield, CT
- 2003 Explorer Sport
I replaced the pads on my girlfriend's Explorer a few months ago, and ever since, the BRAKE warning light on the dash has been on.
When removing the old, thin pads, I had to push back the wheel cylinders to make space for the new, thick pads. This raised the brake fluid level in the master cylinder as you might expect, (I didn't drain out the extra fluid to prevent the master cylinder fluid level from going above the high mark as recommended in my Haines manual). I suspect there was a high-level and low-level switch in the master cylinder, and I tripped it on doing the brake job?
I subsequently flushed and bled the entire brake system. Now that the brake fluid level in the master cylinder is within the high/low limits, I thought the light would have gone off.
I thought this might be an OBDII issue, but my local parts place can't or won't give me any guidance on whether the dashboard BRAKE warning light can be reset, as a CHECK ENGINE light can.
Other threads seem to suggest parking brake issues?
I am at wits end. Any suggestions on a fix, other than a small square of electrical tape applied over the light?
Thanks in advance!
-Stuart
Thanks in advance!
-Stuart
