Albino 94LTD
Recovering from Moab 2016
- June 24, 2003
- Newcastle Wa
- White 94 Limited
- Callsign
- KG7PKQ
No need to remove the bracket unless you're installing a lift.
There are 2 kinds of pivot bushings. The poly ones like Daystar and Energy Suspension slide onto the OEM collar but you have to chisel/grind/cut out the rubber and sleeve to get them in.
The OEM type replacements require you to remove the sleeve and collar. To do that, one side is flared to keep the bushing in place even though it's a press fit (that gives you and indication how much force they take when hitting bumps etc). That flare has to be bent back in or cut/ ground off.
That's the worst part of the replacement:thumbdwn:, the rest is cake compared to that
