Deep Sleep Mode - Battery Drain Issue?
Powerby50
Melville, ny
2020 explorer st
Unfortunately I think that may be the case, this is wonderful as i just made my second lease payment and the car is in the service center. They called today and basically said they see nothing wrong and they want to keep overnight to monitor it.
Join the Elite Explorers for $20.
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
NEWPORTNJ
NJ
2020 ST EXPLORER
What is your build date?
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
Mine is completely dead when this happens, nothing works, door locks, interior lights, nothing. When I hook the jumper box up it clicks for a second before starting. The battery is definitely dead on mine. When I test drove it at dealership it was dead and needed to be jumped, I assumed someone left something on
Once a battery goes dead once, it is never the same and should be replaced.
Powerby50
Melville, ny
2020 explorer st
8/06/2019, they just called me and said something needed to be reprogrammed.. hopefully that was all, besides the battery issue the truck is amazing.
Eric R
Chattanooga, Tennessee
2020 Explorer ST
I had the same issue. The Dealer reprogrammed it and it hasn't happened again. The reprogramming did turn the overhead/dome light on and it won't turn off with the doors closed. I had to turn them off, but now they don't come on with the doors open.
I haven't had a chance to get it back to the dealership to have the dome light corrected.
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve II
Callsign
VE3
Welcome to the Forum Eric.:wave:
Exit32
Location
Boston, Mass.
2020 Explorer Platinum
Took my 2020 Platinum for a 40-mile ride today (mostly highway) and stopped for lunch. Halfway through my cheeseburger, I received a "Deep Sleep Mode Activated" FordPass alert on my phone. Can't believe the battery discharged that much during the 10-15 minutes I was inside the restaurant, so I'm thinking this was just a glitch.
Upon leaving the restaurant, my Explorer started normally and has behaved itself all day. I'll run conductance and load tests on the battery tomorrow.
Powerby50
Melville, ny
2020 explorer st
That makes me feel better that the issue is fixed, I'll check the dome lights.
Exit32
Location
Boston, Mass.
I ran load and conductance tests on my 2020 Platinum's battery today. It passed the load test with flying colors and my Midtronics tester measured 12.40 volts when connected to the battery after the load test. I performed a conductance test with the Midtronics tester, and it says the battery is good to deliver 1,015 cranking amps. Ford rates their factory-installed BAGM-48H6-760 battery at 760 amps, so my battery exceeds expectations.
FWIW, here are pics of volts and amps shown on the Midtronics PBT-200 tester:
RickyG
Texas
2020 Explorer Limited
Callsign
I
Good to hear that there is nothing wrong with your battery
TonyST
Palm Beach Gardens, FL
2020 Explorer ST
Callsign
KW4WO
Did anyone get another Deep Sleep notice today? I got one just before 7 Am this morning. I hadn’t driven it since Sat afternoon and battery is fully charged. Should only do that if 14 days without a start or battery voltage drops below 9.5 Volts. Sounds like FordPass is having a some issues
Powerby50
Melville, ny
2020 explorer st
Figured I would post an update to my truck dying after a day off not being used. They updated the program at the service center and everything seems to be working as intended. I let it sit for two days and it started right up. No more deep sleep messages either.
Explorinum
Location
NY Area
Boss OKd a '20 ST.
So I need some advice with the battery drain issue.
The CE(verything)O at home has okay-ed either a Platinum or ST for the first half of next year.
Our garage is a few blocks away as we live in an urban environment. We primarily use our car on weekends only. And there are times that we might not use it for a few weeks also - I recall not using our car for about four weeks once in a while. Never had a problem starting up with the current car [2015 Hyundai].
How much of a concern should this drain issue be to us?
We cannot install a minder/tender. And I am not sure how the garage would feel about us remote starting it either.
Any recommendations and inputs would be greatly appreciated.
Thank you,
Jay
Spacey
2020 Explorer ST
Just my opinion, but any car that has the battery drain in a few days of non-use is broken and needs to be fixed. I have an Audi that is chock full of electronic stuff that sometimes doesn't get driven for many weeks. It has never failed to start and this with a 7 year old battery. It will go into a mode where the keyless entry shuts down and you have to push the button on the remote to unlock the door, but that's it.
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
Thank you,
Jay
I would not worry about it. Manual says 14 days without starting will enable deep sleep. This is to shut down all the wireless (ford pass, 4g modem etc). You will still be able to start your car when you get inside.
Explorinum
Location
NY Area
Boss OKd a '20 ST.
Thanks blwnsmoke:
I re-read all the original posts and the various other forums you had mentioned way earlier.
Seems like a few hits and misses but all works out. Will probably request a new battery or do it myself when the time comes as a little precaution.
Jay
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
Thanks blwnsmoke:
Jay
Keep in mind you can also shut this off via forscam so if you want to prevent any of those warnings from popping up, you can.
TBill
Prescott, AZ
Why can't you install at battery maintainer/tender, seems like that would be a good solution.
T Bill
dstewart51
Lake Hughes, CA
2020 Explorer ST
Callsign
KJ7E
T Bill
There is no reason why you cant. But the message appears to be inaccurate, just a software glitch or the trigger is a bit too sensitive.
Explorinum
Location
NY Area
Boss OKd a '20 ST.
Hi TBill [if this question is posed to me]:
The reason we cannot install one is because it is a public garage and where our specific spot is, there are no outlets nearby.
Jay
RayoVac Stock 2020 Ford Explorer & Aviator 7
Similar threads
Possible Deep Sleep Fix
