Deerfield Precision Braided SS Brake Lines | Page 2 | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership! If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
96ExplorerX
96 Sport 2WD
I installed a set of the WRXtra SS brake lines on my 96 Sport this weekend.
http://www.deerfieldprecision.com/catalog/index.php?cPath=89
Install went amazingly smooth. Not one fitment issue. The connectors and brackets all lined up and fit like OEM. I didn't use their copper banjo bolt washers though. They seemed too thin and easy to tear up. I just re-used the original Ford washers. Probably should have bought a new set of Ford washers.
On initial pedal movement, brakes seem to respond more quickly than before. I don't feel any significant increase in braking force. Just more responsiveness to pedal application. Overall I'm happy with this brake line kit.
Holiday Special! Join the Elite Explorers $20 for 2 years! Gets rid of the ads!
93 x_SPORT
GARRETT, IN
2001 Eddie Bauer V8 AWD
I noticed something the other day. I used to get pulsing in my pedal when I was almost all the way stopped (like a warped rotor or something?). It doesn't do that anymore. Really liking the upgrade.
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
Any added feedback after more driving? I'm ready to pull the trigger if you guys say they are a worthwhile upgrade. TIA
93 x_SPORT
GARRETT, IN
I think they are great. Was kind of expensive to have installed, but I would do it again. Might be a better deal if you can install yourself.
swshawaii
Kailua-Oahu, Hawaii
Got my lines installed today. Picked it up from the mechanic. All they said was the old ones were "fun" to get off.
Thanks for the comments and feedback. Somehow, I'm not seeing the level of difficulty your mechanic describes.
Must have been seized from corrosion, right? My fittings appear clean, spraying penetrant over night can only help.
93 x_SPORT
GARRETT, IN
Yeah, you should see the underside of my truck. It's pretty rusty under there. I'm not surprised at all. It took forever for me to just change shocks!
CorbinDallas
Calgary
1996 5.0 EB/2005 Aviator
Finally got the time to install the fronts. Very easy to install them, great fit. Rear rotors are stuck on the ebrake shoes, so I may have to cut them off today.
intelisevil
Sandy, OR
'00XLT-SOHC,'99Mounty-5.0
Off Subject . . .
This is how I got my stuck rear rotor off after spending a week with PB Blaster, big & bigger hammers and multiple pry bars (Yes, I had backed off the parking brake shoes all the way!):
http://www.harborfreight.com/12-ton-hydraulic-gear-puller-66657.html
I think Santa will have to buy some new brake lines for my Mounty.
Dan
USMCBuckWild
Camp LeJeune, NC
2007 XLT
Did anyone establich if these fir the later year (06-10) Explorers?
intelisevil
Sandy, OR
Time to do some front end work including brakes so I'm gonna get these.
I'm currently sitting at stock height. I'm planning on raising up a little to fit some bigger tires within the year. These brake lines are available for a 2" lift for only $2 more.
My question is: Will I have any problems with the extra length of hose until I do the lift?
Thanks in Advance,
Dan
swshawaii
Kailua-Oahu, Hawaii
Should be no problem with the extra length as long as they are not kinked or snagging on anything.
If there's an issue with light rubbing, 1/2" O.D. spiral wrap or split loom tie wrapped in place works well.
frankcal
Perris, California
03 Sport XLT 3.73C, 5R55E
I just installed the lines last week, fit was perfect on them. I got mine with a four inch lift option since I was putting on lift spindles and didn't want to bend my hard line.
I didn't use the copper washers that were supplied either, they looked way to thin.
As for performance wise they feel good, faster pedal response. But I switched my rotors to ranger ones and new pads so i caught really speak on their stopping since I have small rotors now. But the cost for me was worth it
swshawaii
Kailua-Oahu, Hawaii
Bump for pics. Testing this weekend. Will post results and opinions here.
Oops! Forgot to update this post.
Won't claim shorter braking distance, but like most a much firmer and positive pedal feel. May be my imagination but the brake pedal also feels higher and the travel shorter. Know it wasn't old fluid or pads because I recently did a flush using the same Wagner TQ front and rear pads. Keep in mind these are installed on a lowered ST with stock rims and Michelin street tires. Oversize wheels will unlikely give the same result. Only regret is not doing this earlier when I started this thread in 2013.
Winner IMO.
intelisevil
Sandy, OR
I installed these last Summer on all four corners including new calipers (with Speed Bleeder screws), rotors and pads. My '99 5.0 AWD Mounty is the best braking vehicle I have ever driven! I do a LOT of mountain driving, nice firm feeling from the first movement of the brake pedal.
I know it wasn't just the brake lines that improved my braking but the price difference was only about double the price of "normal" ones so I thought it was a no brainer to include them in my brake job.
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
It's good to hear that those SS lines are working out.
I will need to get two more sets for my rears, but both trucks will get different calipers and rotors first. I have the 03-06 Crown Vic pieces to try on my mail truck, hopefully those will retrofit, if the housing bracket will bolt on. They have vented rotors and are a hair larger diameter, I've had them for ages so that's where I'll stick them.
intelisevil
Sandy, OR
I will need to get two more sets for my rears, but both trucks will get different calipers and rotors first. I have the 03-06 Crown Vic pieces to try on my mail truck, hopefully those will be easy to retrofit. They have vented rotors and are a hair larger diameter, I've had them for ages so that's where I'll stick them.
You've piqued my interest!!!
Please tell me your "mail truck" is one of the 2nd Gens you have listed in your signature. I'd really like to do an upgrade to the rear brakes using Ford parts.
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
Yes, the 99/93 is my mail truck, it's been un-driven since the V6 trans died about four years ago. All I've done to the brakes on that is swapping Sport Trac(and 01-03 Sport) spindles onto it for the bigger front rotor, and buy cryo-treated rotors.
I do not know if the other Ford rear brakes will be an easy swap, but if the spacing of the rotor to the axle matches, and the brackets can be fitted to the housing, the rest will be the parking brake cables, and the brake lines. The effective brake forces are based on brake pressure(master cylinder), caliper piston areas, and the rotor sizes. Most people think of those backwards in importance. The 2nd gen Explorers use small rotors, big caliper areas, and decent fluid pressure. Mustangs have big rotors, small caliper areas, and decent fluid pressure(plus there are 3+ choices of MC). We have the Ranger MC to possibly use, I'm hoping it reduces pressure just enough to allow my next caliper change(massive pistons(5.44sqin)) to work without locking up the tires too easily.
But the Crown Vic brakes are common, hopefully the parts match close enough to make it no big trouble to retrofit. Later cars might be even better or worse, I got the 03-06 parts long ago, when they were still kind of rare in junk yards. Now they are common to find.
Azscort
99 Explorer Limited
Sorry to resurrect an old thread but I ordered some brake lines from Deer Precision online but can't get a hold of them. Are they still in business?
SupaSwope
Florida
99 Mountaineer 5.0 RWD
Yes I just ordered some a few weeks ago along with a pressure gauge. Guy contacted me a week later saying one of the fittings is back ordered and would take an extra week if I wanted to wait. He refunded the pressure gauge for me free of charge.
Azscort
99 Explorer Limited
Whew, glad to hear it. I have emailed and called over there but haven't heard anything. I was worried they took my money and ran.
