Steveyp21
- April 22, 2022
- Bonaire
- 2007 Explorer Eddie Bauer
I recently had an issue with a 2-3 flare and P7033 and P0745 codes on my 5r55s transmission in my 4.0L 2WD EB explorer. Initially replaced the Shift Soleniod to no avail, followed by a servo change in both OD and Intermediate. Finally dropped the trans out and found a broken Intermediate band. Stripped the trans down and replaced both bands, rebuilt and put it all back in. Had an issue when I put it back where I must have left one of the trans cooling pipes loose and predictably trans fluid filled the garage floor. Remedied this and refilled the trans and seemed to be working fine. Took it out for a rest drive around the block and all gearing seems to work just fine. Got back to the house and selected reverse...
Had a 4/5 second delay followed by an extreme hard shift that slammed the whole car. Moved between R and D a couple of times to see if it eased or was just bedding in. Seemed to get a little worse, then the main radiator pipe popped off under the hood and sprayed coolant everywhere!
I put the pipe back on and refilled the coolant. Now when I turn run the car in park it sounds like I am getting a hissing noise from the back left of fhe engine compartment.
Firstly any help with the harsh reverse shift? Has had new filter, new shift solenoid and oil level is good.
Secondly any idea why the pressure built so much that the radiator pipe popped off? It must be something I did on the trans as I didn't touch any of fhe engine components?!
Currently only showing P1000- FF code but nothing else, engine temp sits on the middle of H and C so seems ok.
Any help would be gratefully received as I am at my wits end with this car. Nine of this happened before hand so it must be something I have done...
HELP!
HELP!
