Delete or turn off apps? (Stitcher specifically) | Ford Explorer - Ford Ranger Forums - Serious Explorations
Zero Gravity
Hampden Township, PA
2020 ST
Anyone know how to delete an app or disable it from taking over the app on your phone?
I listen to a ton of podcasts using the Stitcher app. Since I got my 2020 Explorer a few weeks ago, Stitcher has been disabled on my phone and it shows up as an app on the Sync 3 system screen. That happened when I "enabled" apps.
However, now the app via the Sync system is severely limited by not displaying all available podcasts. The implementation is just bad. I'd rather continue using the app based on my phone and simply use Bluetooth audio to get the audio into the vehicle.
I tried even turning off Apple Car Play and it still takes over my phone's Stitcher podcast app.
UofMEngineer
Michigan
20' Escape Hyb Titanium
Do you want ONLY Stitcher to not work via AppLink? You could shut off the Mobile Apps feature in Settings to block then all. Not sure if that'll fix your particular issue though as I don't use that app myself.
