I know search. Will do tommorrow, but in the mean time, I have a question.
I was wheeling and my "buddy" kept pulling me when I was out enough.
Here's a vid for what happened. The last jerk is when you can see my truck hit the tree! Tou can hear my exhaust in this too!
Here's the dent.
You can see the bondo cracking in between my fingers.
The gap created under the window from the push in.
These two show the difference between both sides.
Well apparently one of the previous owners had a dent and used bondo to fix it. Looked good minus a few little bubbles. Well, when my truck hit the tree a lot of the bondo went with it. I've sanded it down and painted the parts that were exposed. Now, that it's cold I guess, more is flaking off. So today I bought more sand paper and paint. Am planning on doing the same thing I did before. The picture shows what I did.
My question is, should I use Fiberglass or bondo in stead, or just leave it sanded and painted. More of a "trail look" to it.
I have no experience in the area of body work, except for what I've seen on car shows and what I did in this pic. Which was just removing as much as I could with chisel and sandpaper. Then I painted it.
Will try to get a better pic tomorrow.
Here's the dent.
