Desktop computer: power supply dead?
DB_1
Elite Ranger
La Quinta, Ca.
97 SC Ranger xlt
So I have this older desktop computer that was built by my neighbor in '07. He did this for a living so it's not like he didn't know what he was doing. My neighbor has since moved away so i cant rely on him for repairs. Anyhow the tower recently died on me so I'm assuming it's the power supply. I know next to nothing about building computers so hopefully someone more savvy can chime in.
I can post a pic of the label on the power supply if needed, just need to wait until my phone charges up.
Ritsui
Pilot of dogcraft
Lake Arrowhead, CA
98 Sport 4x4
If it won't power on at all... or it turns on briefly, but shuts down the moment the fans start to spin, it could be a bad power supply. Generally speaking, a power supply failure is the primary thing that will prevent system start-up without causing a BIOS beep code.
Tower (ATX) power supplies are easy to replace. Just make sure to get a well known brand (Antec, Corsair, EVGA) which is rated equal or higher in wattage to the old power supply and be careful about static when installing.
DB_1
Elite Ranger
La Quinta, Ca.
97 SC Ranger xlt
Thanks, it doesn't power on at all...totally dead. I took the cover off to see what I'm dealing with and yeah it looks pretty straight forward.
bats
NY
88 Bronco II
Power supply (PSU) replacement is pretty straightforward. You should easily be able to tell what type of power supply you have by looking at it's label.
Silly reminder but make sure you plug in ALL the connectors. Even the best of us sometimes miss something as simple as a hard drive power connector.
Also note that a replacement power supply may have more power connectors than you actually need. Not to worry, just tuck the unused connectors in and call it a day.
Josh P
Shaggin Wagon
Phoenix Az
1991 aerostar
Everything is notched so it can only go in one way. There is a possibility a bad motherboard could cause this. The old power supplies had a switch, the 286, 386 days. Now the switch is connected to the motherboard. Wife's computer had a stick of ram go bad and it wouldn't power on. No beeps, totally dead.
DB_1
Elite Ranger
La Quinta, Ca.
97 SC Ranger xlt
That's good to know thanks. It will be awhile before I can dive into this but I'll update any progress.
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
The older power supplies with a switch were called AT power supplies. The ones without a switch are called ATX power supplies, and require a power supply tester or a jumper wire to get them started.
Sometimes the circuit board on the computer with the switch could be faulty. That's why it's good to test the power supply before you get another one.
I have a PSUTEST20 power supply tester which has built in load resistors, an LED indicator, and a rocker switch. This is a good item to have if you want to get an accurate reading of the condition of the power supply. You could get one for under $10 or just take out the power supply, and have a computer store test it if you don't want to invest in one for one time use.
It's too bad you're so far away from me. I have more power supplies in my basement & shed than I know what to do with.
chefduane
Texas Elite Explorer
Location
TEXAS!
Plano, TX.
None: SOLD 9/16
Too bad. A few months ago I swapped out my 500w LepTek for a Corsair 750w modular.
(Along with a motherboard & cpu upgrade, new R9-270x GPU, and went from 8g to 16g ram.) The 500w I just gave to a guy at work.
DB_1
Elite Ranger
La Quinta, Ca.
97 SC Ranger xlt
Here's what's in there now...not looking for the best, just want to keep this computer going for awhile longer.
It's a pretty basic setup...dvd drive, card reader and some USB ports on the front.
J Desktop not working Exploring Computers!! 11
Glen4X4 Anyone with wireless Desktop card? Exploring Computers!! 15
ld50 Is there a virus that changed desktop picture? Exploring Computers!! 4
gmanpaint Desktop is dead :( Exploring Computers!! 11
badge49 Windows XP Home, Desktop Acting Funny.... Exploring Computers!! 15
Rick Finally bought a new desktop Exploring Computers!! 17
BrooklynBay Desktop fabrication technology is approaching. Exploring Computers!! 5
G Active Desktop possible in XP? Exploring Computers!! 8
G Dead desktop: Repair/rebuild? Exploring Computers!! 30
E Newer Compaq Desktop Question... Exploring Computers!! 7
Brian1 Time for a new desktop PC, what to get?? Exploring Computers!! 14
Rick Reccomendations for Desktop 'puter? Exploring Computers!! 20
M Leave Desktop Or or Turn It Off? Exploring Computers!! 12
R Desktop restarts on its own? Exploring Computers!! 4
E hooking up laptop and desktop monitors Exploring Computers!! 7
C Desktop icon help Exploring Computers!! 5
C How do you take Screen Shots of your desktop"? Exploring Computers!! 6
mmpc Sync Laptop & Desktop? Exploring Computers!! 18
H Win2k Terminal Server Desktop/Client monitoring Exploring Computers!! 6
chefduane For Sale Computer Components Exploring Computers!! 1
4pointslow Computer Monitor Exploring Computers!! 8
BrooklynBay Antique computer with over 16 thousand transistors (no vacuum tubes). Exploring Computers!! 0
BigRondo Computer Problems - Needle In a Haystack! Exploring Computers!! 19
Burns Calling all computer lovers - PC Build Thread Exploring Computers!! 39
Burns Major Computer Display Problem Exploring Computers!! 14
wood1 Gamers, is this an OK computer? Exploring Computers!! 9
Stic-o Need all EF Computer Gurus Help!! Exploring Computers!! 16
M need computer help. Exploring Computers!! 6
BobWiersema Computer Tip of the Day Exploring Computers!! 4
Tbars4 Moving stuff to a new computer? Exploring Computers!! 10
NHarris New Computer "Mustang" Exploring Computers!! 7
Paraphoe Stupid computer question Regarding hard drive Exploring Computers!! 15
U computer problem Exploring Computers!! 6
M Computer memory problems Exploring Computers!! 3
K Just another day in the life of a computer geek Exploring Computers!! 0
Stic-o Kid screwed up the computer ...sort of.. Exploring Computers!! 4
Tbars4 Computer Guru's- Slow page load help needed Exploring Computers!! 30
Burns Computer is down. Trying to help a friend. Exploring Computers!! 24
9 Computer no worky Exploring Computers!! 19
F Computer help please! Exploring Computers!! 3
T Someone Please Help Me!!!! Big Computer Problem Exploring Computers!! 36
Paraphoe My computer is a trainwreck. Exploring Computers!! 40
S Post Specs Of Your Computer!!! Exploring Computers!! 60
9 Do i buy this computer? Exploring Computers!! 10
D ? for the computer gurus: Exploring Computers!! 10
Donner Help with computer pricing to be sold... Exploring Computers!! 9
section525 Build me a new computer! Exploring Computers!! 24
S Recommendations for new computer speakers? Exploring Computers!! 8
SkanlaxJMO Computer Audio issues Exploring Computers!! 1
T computer won't detect more than one hard drive Exploring Computers!! 19
Similar threads
