DC Dave
- June 19, 2021
- Orlando, FL
- 2006 Explorer 4.6L V8 3v
2006 explorer 4.6l v8 3v. Just replaced radiator and thermostat. Filled radiator w/ 50/50, filled resovoir to cold line w/50/50. Vehicle on level ground, started up, ran for 10-12 minutes, all seemed ok, then noticed significant coolant leaking from between motor and trans, leaking out more on left side like over the left rear corner of oil pan. Also seemed to be coming from inside the flywheel cover(if I'm describing that correctly), that leak also seemed to be more on the left. Further inspection seemed to show a slower coolant leak coming from below the main pulley that is below the water pump. Any ideas as to possibilities of leak origin would be most appreciated. Wondering if there's a freeze plug in the rear of the block or if a water pump leak could somehow be funneled to the rear of the motor. I'm nearing desperation and any help would be greatly appreciated. Thank you
