Detroit Truetrac, 4:88 gears, 8.8 install question | Ford Explorer - Ford Ranger Forums - Serious Explorations
Blackdog
Zillah Washington
2004 F-150, 2006 Ranger
I'm having issues with my new Detroit Truetrac and 4:88 gears. After the axles are installed and the "C" clips are in place an axle spacer is inserted between the axles. A retaining cylinder is then installed and held in place with a snap ring.
The problem is with the 4:88 gears I don't have room to insert the retaining cylinder. Should I grind the ring gear or the retaining cylinder for clearance? Grinding the gears a little are common on the Detroit locker but with the Truetrac I think the grinding could lead to a ring gear failure. Have any of you experienced this before? Thanks
I remember hearing something about that recently... Check out www.randysringandpinion.com... Give those guys a call and they might have some ideas for you...
-Joe
