mikeg216
- October 28, 2011
- cleveland ohio east side
- 1998 ford explorer sport
I did a full tune up on my poorly running explorer and now i have more trouble codes then when i started
did full tune up
Plugs ford plugs
wires from ford
coil pack replaced brand new
idle air controller brand new
egr valve brand new
mass air flow sensor brand new
four brand new oxygen sensors
pcv valve brand new
new tranny pan filter gasket and fluid and lucas tranny conditioner
lucas in the front and rear diff
ford semi synthetic 5-w30 oil 1 quart lucas oil conditioner ford motorcraft filter and oil pan gasket
brakes pads rotors and wheel hub assembly, it failed going down the road that was fun!
Now on to the trouble codes!
p0141
heater condition ( Heated oxygen sensor bank one sensor two)
possible causes faulty sensor bank one sensor two
poor connection
check circuit fuse
p0136
circuit condition ( heated oxygen sensor bank one sensor two)
possible causes oxygen sensor defective
fuel system running rich/lean
engine misfire condition
fuel pressure high/low fuel pump or pressure regulator
p0303
cylinder misfire detected on cylinder number three
possible causes ignition system plugs wires or coil
vacuum leak
injector fault
high/low fuel pressure
p0171
fuel trim bank one condition running rich/lean
ignition misfire
fuel injector problem
questions
Bank one sensor two is it driver or passenger side? and is it before or after the cat
Cylinder 3 drivers side or passenger side? and is it the one at the firewall on the most front one.
Please let me know where i should start trouble shooting these problems. Thanks for your help guys!
Mike Gaebelein
did full tune up
Plugs ford plugs
wires from ford
egr valve brand new
pcv valve brand new
p0141
poor connection
check circuit fuse
p0136
p0303
vacuum leak
injector fault
p0171
ignition misfire
questions
Mike Gaebelein
