chartquist
- January 23, 2016
- Memphis, TN
- 2016 Explorer Sport
I have a 2016 Sport, just about 2 years in service and 31,300 miles. The battery has been sounding weak on startup, and I tested it at 12.35 volts. A bit disappointed that it conked out after barely two years of normal use. Since it's under warranty, I took it to the local dealer yesterday afternoon. After over an hour of it being hooked up to their super duper tester (apparently it tests the battery under various loads and recharging scenarios), they finally declared it dead and replaced it. I didn't visually inspect the new battery at the dealer. However, I did ask the service guy if they did the BCM reset. He didn't appear to know what a BCM reset is, and referred to a "master reset" that they did, and went on me some long-winded answer about phone pairings. I'm still not certain that they did the BCM reset, but all of my presets are still just fine and I guess it's not the end of the world if the vehicle still thinks it has the old battery, right?
Lo and behold, when I got home and visually checked, it's a totally different battery model! I was expecting a like-for-like swap to another battery with the insulation and the new one has none. The replacement is a Motorcraft BXT-65-650 model. I wasn't thrilled by this since I presume Ford chose the insulated battery on the 3.5L's for a reason. I called the dealer back this morning, and they said that the new battery is what they call a "red top" as opposed to the stock "black top" unit and the new one is actually superior in every way.
Am I being fed a load of crap? Any reason I should be concerned about the lack of insulation? Should I ask to have the stock model in there instead? I know it's just a battery, so probably no big deal, right? If the vehicle wasn't under warranty I'd just go to Costco and get an Interstate for a replacement. I just expected the warranty replacement to be the stock part and not a different battery model.
