diesel oil
jimbo74
Elite Exploder
Nor*Cal
2001, F150, XLT 4x4
what is the api spec required for out trucks? i would like to run a diesel oil in my truck. i dont do the whole synthetic thing, and diesel oil is usually available cheaper and in larger quantities. 15-40 works for me....
jimbo74
Elite Exploder
Nor*Cal
2001, F150, XLT 4x4
why not?
it is cheap, readily available, going into my truck with a bit of mileage. i have heard diesel oil has a higher detergent content, i am ok with that, it is still oil, its not liek its going to be alcohol or something. its in a weight i can live with, if i dont run it, i will probably end up running a 20-50 weight
dkchrist
Fayetteville, AR
93 XLT 4DR
if you are going to run diesel oil i would be running a 5w 40 oil because unless you are burning oil there is really no reason to run it.
jimbo74
Elite Exploder
Nor*Cal
2001, F150, XLT 4x4
i wnat the heavier weight, truck is old, has 208k, its loud, and i wnat the extra cushion of a thicker oil
what is the api service designation of the explorers?
Sams01XplrSprt
Southern Cali Explorer
Newport Beach California & Bay Area California
2001 Sport (sold)
what kind of truck is it jimbo
Rotor
Ringgold Ga.
94 XLT 4x4
Rotella T is great stuff, a lot of the dirtbike communty is now running it in all their bikes. I run the full syn. in all 3 of my 4-strokes, and ran it in my GSXR before i sold it. Good oil is very important in motorcycles, since they see a lot more dirt, water, and mud and rev to 10,000 + rpms most of the time. It`s as good as the top brands but a whole lot cheaper.
I`ve been thinking about running the full syn. in all my cars, but at $16 a gallon for the Rottella, good ol` Castrol is a lot cheaper.
302Xplorer
Richmond,Va
'00 XLT
Here is a list of all of the API service designations, current and obsolete.
Looks like you '84 yota would have been running SE, so anything more current than that should get the job done, including 15w-40 Rotella.
SM Current For all automotive engines presently in
use. Introduced in the API service
symbol in November 2004
SL Current For all automotive engines presently in
use. Introduced in
the API service symbol in 1998
SJ Still current, nearly obsolete For all automotive engines presently in
symbol in 1996
SH Obsolete For model year 1996 and older engines.
SG Obsolete For model year 1993 and older engines.
SF Obsolete For model year 1988 and older engines.
SE Obsolete For model year 1979 and older engines.
SD Obsolete For model year 1971 and older engines.
SC Obsolete For model year 1967 and older engines.
SB Obsolete For older engines. Use this only when
specifically recommended by the
manufacturer.
SA Obsolete For much older engines. with no
performance requirement. Use this only
when specifically recommended by the
manufacturer.
IZwack
Moderator Emeritus
Germantown, MD
1998 Ford Explorer
I'm feeding my PowerStroke Chevron's Delo-400 15w40
Runnin'OnEmpty
Southeast USA
2000 Sport
Lowered anti-wear additives in SM rated oils.....
Many folks are going to diesel rated oils because of lowered ZDDP and phosphorus levels in the newer SM API rated oils. These are anti-wear additives that have been lowered from about 1200 ppm in the older SL rated oils, to about 800 ppm in the SM oils.
These anti-wear additives are especially needed for engines with flat tappet valve trains, and diesel oils still have the higher levels.
jimbo74
Elite Exploder
Nor*Cal
2001, F150, XLT 4x4
the 208k i was talking about is in my 96 ford explorer.... i plan on using the same oil in my toyota as well.... that oil i pictured above is 2.5 gallons and is like 10-15$ at walmart......
i am not interested in synthetics on either of my engines, they are old
jimbo74
Elite Exploder
Nor*Cal
2001, F150, XLT 4x4
iwould never swap in a 6.0l psd, they are crap compared to the 7.3s
the rotella above,says cj-4, cj-4 plus, sm, it says others, but i cant tell what they are.....
it does say sm, so by that class, it looks good to go... no problems.... sweet :) ima run it in both my trucks, possibly my parents ford ranger too, its got like 150k on it
302Xplorer
Richmond,Va
'00 XLT
Run it without fear, it would be a great oil in any of those applications. :thumbsup:
