MikeTX
- January 4, 2016
- Ft Worth, TX
- 1999 Ford Explorer XLT
So what's the difference between the steering knuckles on the 2wd and 4wd besides the hub assembly? Because I have a 2wd and I'm 99% sure it needs rotors and new wheel bearings. I'm not sure if the spindles are damaged, but the truck has 170k on it and whoever owned it before me didn't take great care of it, so there could very well be damage to the spindles. And if so, I don't want to keep replacing bearings every few months and I've had a hard time sourcing new spindles that aren't lift spindles.
So I was wondering, if I went to a salvage yard and grabbed a pair of OEM 4wd/awd knuckles, would it bolt into my steering and suspension without any problems? Like are the diameters of the ball joint pins and tie rod ends the same between the models? And would my factory break caliper and caliper mount work on the 4wd knuckle or would I have to swap to the 4wd caliper and mount?
I figure if I can pick up a set of knuckles for cheap enough, grab a set of hub/bearing assemblies off ebay, then new rotors and pads, I could get the ease of the 4wd setup for future break jobs, and the longevity of the one piece bearing assembly should it ever go out. I'm just not sure if it's possible. Any input?
