Hey all!
I did a little searching on these forums, but only came up with a few posts with reference, in specific, to metal halide bulbs, but no one seems to have talked about using one of these lamps for use as an off-roading light.
most of these types of lamps are sub-$50(but require a ballast), last for about 10,000 hours, and have the 'perfect' 4200k color temp. I'm fairly sure I can throw some type of simple reflector together with some math, to get one of these to project in many different ways.
I got this idea, while drawing up ideas for a DiY Projector, over at lumenlabs website, don't know if any of you are into that. ANYWAYS, these bulbs are cheap, efficient, and from what I've seen and tested, can actually take quite the beating(vibrations and dropping them lol). The reflectors I have for them are made to point as much of the birghtest part of that lamp, directly perpendicularly(ish) towards a lens, that will refract it towards an LCD screen uniformly, so I would have to build/make/buy some type of high-heat reflector...
I can do the wiring for them too, and I don't mind putting the extra strain on the alternator, my trucks almost 12 years old, so whatevs.
Might not be as efficient as a HiD lamp, but would be about at least an 8th the cost, and a fun sunday project, ya know?
While we are on the subject of different light sources, how about retro fitting one of those high wattage construction lamps, I have one that I've dropped countless times, at least once or twice from 2nd/3rd story window/painting rack, and the fixture was fine, and most of the time the bulb was fine too!
thoughts?
thoughts?
