Different Size Tires on a 4x4 | Ford Explorer Forums - Serious Explorations
reigle
hills grove, pa
i want 255/55/17 tires in the front 275/50/17 tires in the back, the front tires measure 27.2" tall and the rear measure 28"..is that to big of a difference to use the 4x4 without messin anything up?
thanks for the help
I think you will probably be fine, but you might get a ABS light on.
As long as your not limited slip, you should be fine.. If you have a limited slip axle try to keep the same size tires on the axle.
