Differential oil | Ford Explorer - Ford Ranger Forums - Serious Explorations
Differential oil
chuckwagon101
Texas
1999 Explorer sport
I have a 1999 Ford Explorer Sport......6 cylinder.....SOHC .....4 wheel drive....
How do I tell what WEIGHT rear transmission oil to put in? The manual says some take 70-90 and others take 75-140.
Thanks, Chuck
chuckwagon101
Texas
1999 Explorer sport
On the door frame is a sticker that has the word "axle" among others. Under the word "axle" is the number 42
chuckwagon101
Texas
1999 Explorer sport
I don't understand "75W-140 should be fine"
Is this the recommended oil for this differential?
Ronin8002
Virginia
2008 XLT Ironman
well I do know Ford used to recommend 75W90 but put out a TSB stating to upgrade to 75W140. 75W140 will work fine for you unless you expect to operate the truck a lot in sub zero temps, then you might want the thinner oil.
Edit: corrected 75W90 from typo of 80w90
Ronin8002
Virginia
2008 XLT Ironman
also the fact that you have 4.10 gears means that they could run a bit hotter than a numerically lower gear ratio. That, and if you expect to be running in hot weather, also suggests you might want the extra protection that the 75w140 offers over 75W90
