shamaal
- April 25, 2005
- Friensdwood, Texas
- 91 Mazda Navajo
Well poop, it's always the stuff I know nothing about.
Turn left at a stoplight outside work parking lot and hear a crunching sound in front. Pull into the parking lot at work, look under the car and a couple drops of oil are under the front differential. All in all the car had about two blocks on it with an occasional crunching sound when turning the wheels while moving. No noise turning wheel while stopped.
Plan tomorrow is to fill differential with oil, drive around parking lot, hope for no noise and limp eight miles on home. If noise I'll probably get tow from AAA.
1. If differential is dry does crunching when moving and turning sound like a symptom?
2. Where's the leak? There is oil around passenger axle seal but this looks like a real leak. Is there a seal for the cover?
3. Ujoints feel tight, but I know that doesn't guarantee they haven't seized. Vehicle has 140K on it.
4. There appears to be a disconnected hose atop the differential, I assume that's a vent?
I've located enough search threads (out of 1272) to remove differential, so thanks to anyone who can provide advice.
